cummins600seriesdiesel
- Oct 9, 2013
- 2
- 6
Hello Everyone. I had posted before for my John Deere LX 176 mower not having spark. The rider has been trouble free for years when I bought it used from my local New Holland dealer. I'll give a run down on what I have done to the tractor to get advice on a possible solution. Prior to the tractor stopping completely I noticed at times it cranked awhile before starting. I got the tractor out to mow the lawn and once I got started and ran a couple passes it stopped suddenly as if it were out of gas. I knew the gas was full because I had just filled it prior to mowing. I ran to the store and bought a new in line fuel filter and spark plug. I returned home changing both and it still would not start. I grabbed the New Holland and forks scooping her up to the garage. Once there I checked the tractor finding no spark at the plug. I figured it was a coil issue and went back to my New Holland dealer to order a coil since their sister store is a John Deere dealer. Once at the dealer they needed my tractor info which is as follows (1993 John Deere LX 176 - 14 hp K series - code FC420V-AS10 - e/no FC420VA63547 Kawasaki). The coil arrived (AM121820) $95.16 and I replaced same with no spark still. I then figured the ignitor may have went bad and went to the local NAPA store and had them cross the ignitor $75.00. I picked up the ignitor and put it on still having no spark. I then read where someone said its best to put factory parts, so I returned to the dealer to buy the John Deere ignitor (AM132770) $78.15. The ignitor arrived and I put it on with no spark still. I then went back to Deere for an ignition switch (AM121084) $104.03. Put it on and nothing. Thought unlikely, but I returned to Deere thinking maybe a bad coil. I made the purchase of another coil (AM121820) for a mere $95.16 with the same results of no spark. Well now that I'm $447.50 in this bad boy and love the tractor I can't convince myself to buy a new one. Last year I replaced all the Hydro pulleys, arms, and belt instead of buying a new one because it ran so good. I replaced and bought a new spark plug boot. I pulled the flywheel to check for a sheared key which it was fine. Under the flywheel was packed with grass and dirt. I cleaned the flywheel and inspected the magnets which were like new. I cleaned the the stator and checked the wiring for cracks which may be grounding out and all were fine. I've been everywhere on this tractor and can't find the source of the no spark issue. After cleaning under the flywheel I did notice when I cranked the tractor over, when I released the key I got a couple crisp blue snaps from the spark plug. I placed a spark plug tester in line and cranked it over with the tester showing a very dim pulse and when I released the key the bulb went bright for a pulse or two. Same thing every time I tried it. After I went into the house I began to check the John Deere web site on line. After doing a parts comparison I noticed that every part matched my model of tractor except one, the coil. The coil that was sold to me by the dealer was (AM121820) for $95.16. This coil seemed to go with the (FC420V-DS10, ES10) tractors. After looking it over I noticed my tractor called for (AM109209) for $64.57 on (FC420V-AS10, BS10). Could this be my whole problem, I was given the wrong coil from the start ? The next day after work I rushed home and picked up a coil and receipt. I returned to the dealer to see if they could get the other coil in so that I could try to see if it solved my ongoing problem. A service tech was there and when I explained to them what I had found, he asked if I placed the coil on the correct way. I told him that the coil only has enough wire to go one way. He told me that its either the coil or the stator. The tech asked if I checked the the stator for its condition and the magnets under the flywheel. I told him I cleaned and checked the both the stator and flywheel were both fine. The magnets were solid and intact and the stator showed no signs of cracks or wear really. The dealership told me they would contact me when the other coil arrived. I hope the coil is the answer to my problem so I can get this mower back on the lawn. What do you guys think about the coil being the possible issue. Also if not the coil do you think the stator could be the problem. It doesn't seem to have any charging issues and always kept the battery up. I even replaced and put a new battery.
