john deere LT160 builds momentum and will move just a little
mark69
  • / john deere LT160 builds momentum and will move just a little
I have a LT160. i put a new drive belt on thinking this would fix it but did not. it wont hardly go, if you push on the foot pedal it will builds momentum and will move just some and then it stops .the push rod in back is in all the way . is there an adjustment or something? thanks mark
pugaltitude
Is the belt turning the transmission pulley?
Is the belt too slack??
If the answer to pug's questions are no to #1 and yes to #2 you do not have the belt routed correctly. The belt should have tension at all times.
mark69
Not the belts. thay are good !
xp14629
One of two good possible things. I have seen where the inside of the transmission pulley is stripped and not fully engaging the shaft. It can still allow the tractor to move, it would of been a sudden issue occuring though. Next is if the belt groove in the pulley is so worn that it is not contacting the full length of the vee edges. This is hard to determine for someone that has never seen it before. This would of been a long ongoing issue of losing ground speed.
