I have a John Deere lawn tractor which will not crank over.
Details
It was working fine and after shutting it off to empty crass, it would no longer crank over
Checked so far
Jumped the solenoid just sparked
Replaced the battery
Took the hood off, and watched as the Starter motor engages but will not turn the crank
Pulled the sparkplugs to remove compression and found I cannot turn over the engine by hand
Any thoughts?
Details
Checked so far
Any thoughts?
