Y YUCON Forum Newbie Joined Sep 23, 2014 Messages 1 Sep 23, 2014 #1 this engine is smoking alot (white smoke) when first started, just under 400 hrs. even this b&s 24hp should last longer than that?
M mechanic mark Lawn Pro Community Leader Joined Jul 15, 2013 Messages 7,499 Sep 23, 2014 #2 FAQ | Lawn Mower Safety Tips | Briggs & Stratton Do you check engine oil level before each use? Are you having to add oil frequently? When did you replace air filter last and adjust valves?
