Hey Guys,
New to the forum. Replaced the engine(Intec 20 hp Briggs) on my L120 with a running used engine. I adjusted valves and cleaned magnetos. As I was working on magnetos, I noticed a black wire not connected to the left magneto. Engine seems to run fine. The problem is when you connect the black wire, the engine dies. Both were connected on the old engine. Any suggestions?
