John Deere L100 17Hp
fxm
All local service is running about 4 weeks out up here in Ma.
Start tractor and runs a few seconds and then stops running. At first it only did this when I put it in gear
, now it does it in neutral. I checked in-line fuel filter, looks good, fuel tank is full. Any help with this is appreciated. My acre and a half is getting pretty tall. :smile:
Thanks in advance
Mikel1
Sounds like a fuel problem. If you spray some starting fluid into carb will it keep running?
