John Deere F915 Hydraulic Lines
ah64_ip29
Hi All,
I've just purchased a used John Deere F915 that wasn't very well taken care of and trying to get it operating again. On the hydraulic overflow tank under the seat, there are 3 lines coming off the tank. Where do they go? The bottom one looks like it goes to the top of the transmission. The one on the left side runs forward to a tee fitting, but there is nothing attached to the front of the tee fitting. Is it supposed to run forward to the fitting on the front left side of the differential (nothing currently attached there). How about the line on the right side of the overflow tank. I can't figure out where it might run to. Thanks for the help.
Adrian
