John Deere Engine Paint for 67 110
brizjuan
So I am looking to paint the motor on my 110... I will be painting the rest of the tractor JD green from the dealer but I cant seem to find an exact match of heat paint.. I see a lot of guys painting the motors black but there all also restoration I see that have the engine matching the rest of the tractor? Are they just using the standard paint? Can this withstand the heat?
pile81
When we rebuild our engines we use jd green out of the rattle can and it withstands the heat
Ddfd37
That's what I used on my 110 [1966 and 1970]. From spray can works no problem. And a old trailer. But did clear coat trailer as well.
PJ
If you use the green paint on the engine block it will be ok the exhaust manifold use black heat resistant
Good luck and show us the complete project
P
