geno368
 - Apr 4, 2025
 - 2
 - 5
I have replaced all the deck belts and pulleys and sharpened the blades.  Motor runs great and has good compression.  I have checked push rods and they are fine.  I have replaced carb and battery as well as all filters.
The problem is that when I pull up on the mower switch it starts turning the blades and then shuts off the motor. I can try the switch for a few seconds and when I turn it off the motor picks back up if I don't let it die.
Need help figuring how to turn on this 48" deck....Thank you
