John Deere D105 Blade Engagement Issue
SSBN626
I have a 2016 John Deere D105 that I use to mow my small 1 acre lot. Recently when I engage the blades it may take 10-30 seconds until they actually start turning. I would think I would need to simply tighten the cord/wire whatchamacallit. Mine unfortunately has the L bracket welded so I cant adjust at that point. Any ideas??
Scrubcadet10
Moderator
Staff member
Have you replaced the deck belt?
Have you tried turning the blades by hand to be sure they aren't hard too turn
SSBN626
I have not replaced the belt yet. Look's like I may need to. So, do know if the engagement cable can be tightened?
