Start with battery, are connections clean & free of corrosion? You can remove battery, negative black cable first, then positive red cable & take it to your local auto parts store & have them load test battery at no charge to you. If battery checks out ok then check all electrical connections by hand making sure they are tight & secure including ground straps & cables from engine to chassis.
