Hi all, I have a C108 lawn tractor that won't start. Battery is good, turning the key, there is no click from the relay/solenoid. The ignition switch feels mushy but without a diagram, I can't tell if it's a problem or not.
I am looking for an electrical diagram so that I can chase the issue. Can someone please point me in the right direction? The owner has had this machine at two other repair shops and the problem still exists. That is that it will start, run for a bit and then shut down. Gotta get the beast running first to fix the rest of the issues.
