Prob isn't with the Deere but more with the fuel pump on the unit. Pump is leaking fuel from the weep hole on the backside of it. I thought the fuel bowl may have been culprit but after removing, inspecting, clean and replacement, I'm still with same issue. Ideas anyone. Thanks.
ablecain
Did I jump ahead to the carbs fuel bowl too soon? As in, does the leaking weep hole indicate a faulty pump?
ablecain
