John Deere 425
lorens
I have a 425 john deere and all of a sudden it will not start checked the battery and cleaned the posts but starter will not work does not click or anything.
Ifixdit
Did you check to see if the fuse is blown?
Mary Wilson
You should probably get a wiring diagram and check the starting system with a continuity meter. There's several switches and modules on the 425 and if defective will result in nothing happening when you turn on the ignition switch.
