John Deere 265 won't start
gyattaw
Have a 265 with 17hp Kawasaki that will only start on jumper cable. Replaced battery, twice, rebuilt starter no luck. Could it be the electric mower clutch dragging the voltage down?
EngineMan
Take a look at your first post...! you could unplug the electric clutch and see.
BillyP
If it will start with jumper cables, you most likely have a battery or connector problem.
