Logan Savage
- Nov 3, 2014
- 5
I have a John Deere 125 lawn tractor with a 20 HP Briggs & Stratton V Twin engine . I just bought this mower used late last fall . I was using it for about the third time this spring when I noticed a difference in the tone of the engine . It wasn't making any rattling or knocking noises just sounded different so I continued using it this summer . I did adjust the valves which really didn't need much adjustment . This fall I began having starting problems . It always cranks over fine but sometimes it started right up & sometimes it wouldn't hit a lick . When it wouldn't start usually go out the next day & it would fire right up .
I decided to check the plugs & in the process found one of the spark plug wires wasn't sparking . After I did a little research I took an ohm reading on that coil & with my digital meter set on 20K ohms the coil read 4.2 . One day it wouldn't start & I found that neither spark plug wire had spark . Using the same setting on my meter I took a reading on that coil & it read 4.6 . I had disconnected the black kill wires & still no spark .
I have another mower with a 17 HP engine & I checked the coil on it & it read 4.5 & was running till it bent push rods & I parked it . From what I've read the only things that will cause no spark is either a bad coil or bad magnet on the flywheel assuming the spark plug wire itself is good & the ground / kill wires are disconnected . With the flywheel on the engine I can lay a large screwdriver end against the magnet & it will hold it straight up so I'm assuming the magnet is good .
I'm now assuming the change in the tone of the engine back in the spring was when the first coil stopped firing & the later starting problems began when the second coil began to fail . Is it unusual for coils to fail & cause the problems I have described & what are your thoughts about the ohm readings on the three different coils ? Are replacement flywheel magnets available or does the flywheel have to be replaced if the magnet fails ? Thanks in advance .
