John deer LA 120 problem with pto going forward
1Doubled2
Hi all I have a John Deere LA120 I joined this site to see what other people have problems with this model as it seems that the LA 120 has some issues.
Currently I have an intermittent problem with the PTO works for a while then stops and will only work in reverse. have checked all the switches and now
I am investigating the wiring harness.
Welcome to LawnWorld!
We moved your thread to the John Deere forum.
I assume when you say the PTO does not work, you mean the blades don't turn. The LA-120 has a manual PTO, so wiring should have nothing to do with it. If it was a wiring issue, the engine would shut down, not the Blades. Probably something to do with your belts and pulley's.
