johm deere 2653a
glenn1234
I replaced a headgasket on a 2653a put it back together bled it and it wont start will crank but with very little white smoke
Sounds like you are not getting enough fuel. I would start by rebleeding the system. If that does not work, with an assistant, loosen the injector lines at the head and make sure the pump is working and fuel is getting to each cylinder.
glenn1234
Hi mate done this today my hand promer wont work and cant seem to get much fuel flowing proply do u no a y other ways to get it to come through properly thanks
What engine do you have in this unit?
