JD4100 replacement bulb for ROP bar flashers
Jinzo Ningen
Is the bulb for these 1156 or 1157? (Bulbs I pulled out have no numbers on them.) I want to swap them out with LED bulbs. Thanks.
Scrub the OP is looking at the roll over bar lights. One bulb is the 1156, the other is also a common vehicle light bulb but I would need to do some research them. Anyway 1156 is larger one and LEDs are available for it but I don't recommend them as side viewing of the LEDs is terrible; unless you find ones with LEDs on the sides. The other bulb I doubt there is an LED for it, just no market.
