Export thread
JD X300 , No spark
#1
P
Pinch
not getting a spark, replaced ignition coil, still no spark..
#2
P
pile81
Probably the little control mudule under the dash, its a little black box with wires running into it, its mounted under the dash above the battery in that general area. 2, 10 mil screws
#3
P
Pinch
I just wanted to thank you for the tip, It was the control module...
#4
P
pile81
No problem
