Unplug the two wire connector to the clutch. Take the bolt out that is holding it to the crankshaft, may have to use impact, or put socket wrench on bolt head, and hit with hammer to break loose. Clutch should fall off possibly smashing your fingers when it falls off.
Reverse procedure to reinstall clutch. Torque bolt to 50 ft/lb.
