JD L110 Hitch
Artisan
Gents before I start fabbing something up I should ask if it is already made.
I have a trailer and the connection height from ground up needs to be much
higher than the OE JD-L110A hole.
Does any make a bolt on widget where I can raise the height a lot?
It is a implement type of hitch w/ a pin.
On the trailer, I would call it / describe it as a double tang and pin hitch...
TIA!
