JD gt 245 ignition switch wiring.
Thomasam
Hi guys, back again.Anyone have access to a JD245 tractor wiring diagram for the ignition switch. The original one came apart on me on the grass, couldn't find all the parts.lt was an Idak 6 terminal unit. The replacement I got for it is also an Idak 7 terminal, but not identical, one of the terminals is in a different position and some of the terminal I.D. stamps are missing on the original switch. I have 4 of the 6 connections made it cranks,and the lights work, the pto clutch gets power from it's switch, but the motor will not run. The 2 connections i am unsure about are,a purple w/black stripe with a solid white together on a factory female spade connector, the other is a solid white wire also w/a factory female spade connector. Not sure what year this tractor is but here ar. e the #s M00245B162196 - 245 TRACTOR Kawasaki 14HP.
