milogonzjr
- May 24, 2014
- 1
- 1
Hi all: I have a John Deere 425 with about 500hours that is an awesome mower. I have a 60inch deck and can mow a couple acres in few hours. Was running well but this weekend would not start. Last year I replaced the ignition delay module since it would stop running in the middle of mowing. But now, all I hear is the fuel pump, the correct dash lights come on but no cranking. I have bypassed the switch under the seat and made sure the brake was on and PTO off. The green light on the circuit board in front compartment comes on, the headlights come on, replace with new battery and still won't turn over. I was going to replace the ignition delay module again but not sure that will fix this. Would it be the starter or starter solenoid? Thanks for any help.
