I have power at both headlight sockets with the lights switched on or off. Charging system is outputting properly. What is my next troubleshooting step?
Thanks in advance
If you check for power are you checking for power negative and positve at the globe socket? If not do so. Also see if the contact point is touching the globes contact. If you say you have power with swith on or of then you probably have your ground temanal elswhere on the system
PJ
Thanks in advance
Both bulbs are new from same package.Does not make sense power ok contacts ok! I can then say replace globes. Must be 12 volt
Good luck
PJ
If you say you have 12V power at the contacts of the globes and the contacts are OK the lights must burn. Try and take the globes across 12V battery with a piece of wire to confirm if they light up
PJ
Ya I would say that the switch is bad. See if you have another switch laying around that you could use to just rig up to make sure the old one is bad.
