gforce1108
Every year my father's JD 170 has a good sized mouse nest in it from sitting in the shed over the winter. Before starting it I always clean it all out. I tried to fire it up and it just cranked. Tested spark - none. The mice had chewed the spark plug wire so I swapped the coil from a newer JD mower (17hp kawasaki) and still had no spark. With the kill switch wire removed it would fire. I traced it back to the ignitor. With it unplugged the mower runs great. I thought it was some kind of over temp switch so I had him buy a new one (didn't expect it to be over $70).
I can swap his old coil back in with the new 'control unit' but I kinda like the idea of eliminating it all together. Any reason why I can't run the newer coil from an engine that did not have the solid state ignition?
