JD 135 Wheel Bushing to Wheel Bearing
MKPingree
Having to change both wheel spindles. When upgrading from wheel bushing to wheel bearing I have some questions please:
1) do you remove the grease fitting from the tire rim ?
2) does the outer bushing still require 2 washers before snap ring ?
i ask #2 because some replacement kits come with the two outside washers and some don’t.
Thanks In Advance,
Martin
mechanic mark
You're quite welcome sir. Please let us know how it goes, thanks, Mark
