Export thread
Jacobsen 47" mower
#1
F
fusebond
Will a Jacobsen 47" Commercial mower take care of a 4 acre lawn, i'll be moving to La Grange and am 64 years old, I think it should do the trick.
Rob M.
#2
Briana
Briana
Hey there - WELCOME to LMF! :smile:
I moved your thread to the Jacobsen Forum.
#3
Parkmower
Parkmower
It all depends on how long you want to spend mowing. Most new mowers have a "acres cut per hour" spec.
My 72" front mount says it'll do 4.5 acres per hour.
My 72" zero turn says 7 acres per hour.
I'm guessing that's full speed. But I usually don't mow full speed ahead.
But I think you'll be fine
#4
B
benski
I'll guess you'll spend about 4.5 hrs. to do your lawn.:smile:
#5
B
Black Bart
Rob M.
Yes it will but do you want to is the question?????????
I know I would not want to spend that much time mowing but people do it so can you if you want. :smile:
