I believe it is an early 60's model. I did find out the lawnmower model number and it is a 2V-500387. I also found it that is needs a new carb. After replacing the gaskets in the old one it is leaking gas very badly. The old carb is a Walbro 62-31 and it is stamped 672. I'm not sure if I can get one to replace it or what to do at this point. Any suggestions would be helpful.
