Jacobseen 524 no spark
eadams1998
I have a 524 slice seeder with a brigs And Stratton engine I can’t seem to find anything parts wise matching the model and type number model 233452 type 0331-01 code 7906121 cleaned points and cleaned flywheel and coil still no spark trying to find part numbers for points condenser and coil
Have you tried disconnecting the points ground kil wire?
Most engines can be switched/updated to a none points ignition magneto. Star Tech may have the updated part number for this engine.
This shows to be a cast iron block.
Original coil number was 298968 according to my early quick reference manual. points set 298185.
