IS700Z PTO would not engage..
R-Rocks
Brand new, 2.5 hours, PTO disengaged during mow. The problem was the plug at the clutch, black wire came loose out of its spade. Problem solved, recrimped the wire back in place, 20 minutes.. I post this note just to inform others what was done to fix this issue. Searching the internet I did not find much, looking at the trouble shooting section of the manual was no help.. Belts were in place, and all other electrical plugs intact, fuse good..
FUSE GOOD BECAUSE YOU HAD NO SHORT BUT LOST YOUR GROUND BUY YOU A SMALL 12 V TEST LIGHT WILL SAVE U A TON ON REPAIRS 12 V STUFF MUST GO BACK TO GROUND (BATTERY) NOT ROCKET SECIENCE
