Repairs IS3000Z 27Hp Kohler
RMG61
Bought a uses 2005 IS3000z, 980 hrs, serial # below 875, was stored outside under tarp. Slowly repairing the inherited issues. New rear tires, new aftermarket carb, replaced melted fuse block, lots of grease and WD40 spray. Cannot raise deck with pedal, left rear pivot still frozen after a lot of work, steering jerky and freewheels going down hills after installing new dampners. What adjustments are needed after installing new dampners? Is freewheeling normal down hills? Tips on best way to change hydraulic fluid ? What is needed to keep front caster wheels lubed? Pop cap off and fill grease ? no fittings? The jerky steering and lack of steady control and not able to push pedal to raise deck are major problems that I would like to get resolved ASAP.
Any help with these issues is appreciate! Thanks.
