I have an IS2000Z vintage 2015 mower that has a leaking shaft seal on the bottom of the left pump, the input shaft. Is it reasonable to replace this seal from the bottom so I don't have to remove the pump? I have a chain fall so I can lift the mower however is the best. I was thinking lifting up the front would be the safest.
