is2000z fuel problem
gentech
Hi all, new to the forum so bear with me. I have a 2012 ferris is2000z 61" deck, 30hp briggs that I cut about 2 acres with, last time I mowed I ran both tanks pretty low but never ran one out. Filled both up the following week, mowed about 3/4 of the yard with the right tank then switched to the left, next pass it started to die like out of fuel/gas. So after going through the entire fuel system I am at a loss, will run fine on the right but not the left tank. Replaced filter, checked/cleaned selector valve (even turned it around), replaced fuel lines, checked fuel lines inside the tank, replaced fuel pump, also the machine has 102 hrs on the clock. Any way the evap system could be the issue? Thanks in advance!
