Is JD Tech Manual wrong? Sure seems like it. Just checkin’.
ALD2025
  • / Is JD Tech Manual wrong? Sure seems like it. Just checkin’.
In testing the PTO switch I got the opposite results … as I noted in the manual.
What equipment ?
ALD2025
GX 85
ALD2025
Rider
This is what in the
ALD2025
Thank you for confirming - my manual is wrong. It drove me nutty for a bit.
Auto Doc's
First come the original manuals which everyone seems to get but then come amendments and corrections that no one hardly seems to get.
Sorta like the instructions to pull an axle hub to replace the axle seal which cost me over $200.00 for the tool. Then in the later manual it was remove the axle. Thanks a whole heck alot JD. Now I got one useless in the tool box.
The darn hub is pressure welded by the 300 ft lb torque applied to tapered axle shaft. Even a 20 ton hydraulic press can't separate the joint.
But I used my experience with differentials and how to remove the axle even though it meant pulling the transaxle.
