Hello,
Parts for F engined Lawn-Boys are getting harder (and more expensive) to come by.
I'd check the compression (minimum 90 PSI) to see if it's worth the effort to invest more time and money in.
2 cycle engines are extremely simple in design, and if it's got decent compression, it should run good. If it doesn't it's usually a carb issue, assuming it's got good spark.
Regards
Jeff
Jeff and others I finally had Hubby and I take it to someone in this small county to work on it. well they called and said its ready. $63.00. I go today before they closed to pick it up. As the gal was bringing it out to me I asked that I see it start. well she was a lot younger than me and she couldnt get it to start. The cord is so hard to pull.
Hubby should have went with me.
Well she called out a guy ..he couldnt start it either. They said it had a choke button on handle,,, yeah I saw it Our older LBs. all previously... had a push button to prime the engine. I remember.
they pushed it back to the back area. Later saw her come out saying it needed a carb gasket. since its an old mower parts hard to come by. So I told her I would check back next week. So disappointed. Hubby says "leave it there ... junk it it s hard to pull cord.., etc"""" It about pulled his shoulder out of whack when we bought it used and he tried lots to get it going sev yrs ago. So Hubby gave up and let it sit in shed.
I say "heck no it has an alum deck and a lot easier to push back into and up hill into the garage...." i dont wanna give up so easily.
Now I meant to ask the mechnic that SUPPOSEDLY worked on it. What he did to it...
so the saga continues.. Thanks all
I wanna it to work... Im hard headed....
