Engine intek 21 hp , poping back through intake
bobed63
intek 21 hp popping back through intake and building pressure in crankcase. but will hold 175 psi when checked compression
NorthBama
have you adjusted the valves
TobyU
Twin or single? I thought 20.5 was biggest single but not sure.
Either rocker arm stud loose and/or bent push rod, on twin-push rods bent / jumped off rockers-possibly caused by slipped valve guide from over heating, or popped out intake valve seat.
I just had to pull one off mower and take crankcase apart to remove bent pushrod ingested inside after it slipped exhaust valve guide bent pushrod and jumped off rockers-possibly then found its way into block.
JonnyBlaze
Broken flywheel keyway?
