Instrument screeen question on Tiger Cat 2
Called. Can't do it. Will explain tonight.
You do have the large canister filter don't you?
Seems Scag should be able to advise you on what to do, have you checked with your dealer?
Yes, I ended up calling a local Scag dealer. A couple of the guys there looked around some and found that the 25hp Kohler has a spot on the elbow just below the filter housing for the sensor. The 29hp doesn't have a location for the sensor. We talked about work-arounds but decided against. On the bright side, apparently Kohler makes a sensor I can install; I just won't be able to incorporate it with the Tiger Eye display.
