installing a 691840 link choke
sfowler5
how to install a 691840 link choke on a john deere series 100
You are going to have to remove the carb from the engine. Hook the choke link into the choke. There is a large control plate on your right and if you look on the back side of this plate you will see a slot for the other end of the link to slide into while reattaching the carb. Quite simple to do.
