install grease fittings??
glennsjr
Replaced the spindles on my sltx 1054 Do you think it's worth drilling tapping and installing grease fittings ?? I know they are sealed bearings but my understanding is the grease helps absorb some of the heat so they will run a little cooler. Just curious
