Finally checked my own mowers for spark or proper healthy spark.
See the first line on the far left in the SE or small engine area? Very first one. I have two older Briggs push mower engines that would barely pop that far. One was less than that line a touch. 3/16" or less like hardly anything. And if you run a resistor plug, you have less spark than that. Oh my test was without the plug and grounded to the block, bare metal. Now running ALL non resistor plugs in everything.
