In over my head again
sano888
Told the church I'd take a look at their mower. Cub Cadet 3660 (predecessor to the M60 tank?). Presenting problem was mower shredding the deck drive belt. However, it will not crank. I can hear a click with key turn. Not sure if it's starter solenoid or carb solenoid. Not even sure if it has one on the carb. New starter solenoid. Battery fully charged. Both paddle switches and parking brake switch appear to have continuity. My next guess is checking PTO switch and key switch. Am I on the right track? Am I missing something? I am Youtube trained so speak slowly. Any help would be appreciated.
Auto Doc's
Sounds like the battery needs to be load tested to make sure it has enough amperage. A multimeter only reads voltage. Voltage is only "potential" to do work, the actual work is done by the amperage. Have the battery tested at a parts store before going any further.
Looking at the last pic, those electrical terminals are filthy. Make sure you have good pin fitment and all is CLEAN.
sano888
I have an extra battery. I'll give it a try. Currently I get nothing but a click.
sano888
I can do that. Somebody's been in here. The plug to the PTO is full of dielectric grease.
sano888
Used some Lectra-motive cleaner on the grease and wire brushed the switch. Tested OK. Started right up. Now on to why it's throwing a belt. Stay tuned.
Easy with the wire brush. Polishing/cleaning is what I was referring to.
