Ignition Coil OHMS
Hottech
I have a Husqvarna push mower with a Briggs and Stratton engine model # PO2-0116-F1 that has no spark so I pulled the coil out and it reads 6.1 Ohms on the ground and also on the male tab. Does anyone know what Ohm reading I should be reading? Should I just buy a new coil ignition or am I barking up the wrong tree?
You got either a 111P02-0116-F1 or 114P02-0116-F1.
Either way there is no reliable to test other the go, no go test.
