OK, I found a tow behind trail cutter I plan on buying. Listed at 650lb gross weight. 2 wheel deck, looks like reasonably balanced on them.
I am dead set on using ATV to tow it behind as I have 1.5 acre of wetland that needs 4x4 and good grip. Same time, I am not going to buy a fancy new ATV or UTV. Used, of course.
As I know nothing about ATVs, but seen plenty of them tow behind mowers pulled by one, question do I have.
If you tow behind a mower:
What kind of ATV am I looking at for 650lb trail cutter? I figured, likely in 700/800cc range. Of course, driveshaft. Does it matter if it's automatic or manual?
