Idle on 2006 22hp briggs
muyoung
Engine runs normal at high speed with or without load,but at idle it runs rough with a rhythmic idle and will backfire threw carb. Rebuilt carb. This carb does not have a needle valve just a plastic cone that sits over elc. solnoid. Modle is 446777 with a nikki 698494 carb. Or could I have a porblem other than the carb? Thanks.
The jets are up inside the plastic cone you need to run a paper clip, or small wire up in them to clear out any debris that might be in them. It sounds like it has debris/ trash in the low speed jet I couldnt tell you which is the low speed jet so just clean them both to be sure. Also make sure the breather tube is on the throat, and hasnt come off the back its the black tube right on the back of the throat between the throat, and flywheel.
e black tube right on the back of the throat between the throat, and flywheel.[/QUOTE
Thanks for your reply, Gone for the weekend will pull carb. Monday and clean again.
Finely got home pulled carb off recleaned and replaced manuitfold gaskets, also replaced flywheel key.
No good still will not idle right. Any help with this problem would be good.
Thanks again for help.
Roger
Thanks for all the advise, ordered a new key and a gasket set. I also heard these engines have some problems with loose valve
seats. Anyway going to try to get repaired next weekend, on the road a lot this spring.
Again thanks a lot for all the help.
Roger:
