I sold my outboard motors and Chevys, no longer have a need for these parts.
wickedgoodoutdoors
  • / I sold my outboard motors and Chevys, no longer have a need for these parts.
_______________________________________________________________________________________
FOR SALE: I sold my outboard motors and Chevys, no longer have a need for these parts. (Can Ship)
Let me know what parts you want, add a reasonable amount of postage (example add $5 to ship power packs or $10 to ship cables ) and send a check for the total along with your shipping address.
WickedGoodOutdoors@Maine.rr.com
Southern Maine
WILL TRADE!
Equal Value of Parts for a new 16 to 18 ft skiff or firearms or a couple of new Sea Kayaks 16 to 18 ft or 80W t0 130 W Fishing Reels
Some are New Some are fresh water USED.
QTY DESCRIPTION New/Used Price Ea. Extended Price
Brand New Stainless Steel American Made Zippo lighters Just $20 each
Excellent cond. used Stainless Steel American Made Zippo lighters Just $10 each
1 Teleflex SeaStar steering Hydraulic Helm Tel Part# hh5271 1.7, 6.9mpa 100psi $299
3 "Water Pump Impeller Teleflex 18-3056 Impeller - Dia. 3 1/2"",Dpth. 1 1/4"" - 6 Fins - Neoprene
Honda # 06192-ZW1-00 Fits Honda 75HP and Mercs 4743026-2 and others. New $10 ea
4 Johnson/Evinrude New Stainless Steel Steering arms for outboards ( Will fit other brands) New $25 ea
1 Johnson/Evinrude Tilt Pins retainer Bars for Johnson/Evinrudes ( Will fit other brands) New $5
2 Johnson/Evinrude VRO hose & Pump & Sender unit New $75 ea
1 Johnson/Evinrude Alum TRIM TAB 327640 OMC New $10
1 Johnson/EvinrudeVRO Kit Part # 438406 includes Pump #175161 New $100
1 Johnson/Evinrude Zinc Skeg trim tab New $10
3 Johnson/Evinrude #323664 Spline Gear New $25 ea
1 Johnson/Evinrude drive shaft 85 to 150HP New $50
1 Johnson/Evinrude Clutch dog OEM #22683 OEM #319895 New $50
2 Johnson/Evinrude Helical Lower unit Gear sets # 340490 New $50 set
4 Johnson/Evinrude 90HP-150HP Rod Bearings set New $40 set
1 Johnson/Evinrude New Rectifier/Regulator Kit #CD4 583110 9GR-0A New $50
1 Johnson/Evinrude New Rectifier/Regulator Kit # 395391 New $30
1 Johnson/Evinrude Ignition Coil Kit # 583737 New $30 ea
2 Johnson/Evinrude Ignition coils #582508-0560-0A New $10 ea
2 Johnson/Evinrude POWER PACKS OMC CD4 584027 New $5 ea
1 Johnson/Evinrude Voltage Regulator Kit # 173640 New $100
2 Johnson/Evinrude Timer Base Kit #583376 New $100 ea
1 Johnson/Evinrude wiring electrical harness for controls to engine with big red plugs New $50
1 Johnson/Evinrude Water Pump Impellers for 85-150 HP New $10
1 Johnson/Evinrude Complete Water Pump kit for ? HP #391391 New $40
1 Johnson/Evinrude CompleteWater Pump kit for 85-150 HP Part # New $40
2 Johnson/Evinrude Evinrude Johnson 3" Tach & System Check Gauge.New $110 ea
2 Johnson/Evinrude Trim Indicator Gages New $50 ea
1 Johnson/Evinrude lower unit Gasket #286279-2 New $10
1 Johnson/Evinrude Complete Gasket set #139300 fit 85 to 150 HP V4 motors New $20
2 Johnson/Evinrude Rubber Exhaust Gaskets fit 85 to 150 HP V4 motors New $5 ea
6 Johnson/Evinrude Gaskets # 317914 fit 85 to 150 HP V4 motors New $5 ea
1 Johnson/Evinrude Gasket # 359-317955-1 New $5
9 Johnson/Evinrude Gaskets # 194-321727-1 New $5 ea
1 Johnson/Evinrude Gasket # 436-323459-1 New $5 ea
5 Johnson/Evinrude Gasket # ???? New $5
10 Brand New Valves for Inflateable Boats. New $20 ea
2 Aqua Power Impeller JP 28948-001OMC #509182 Fits Jabsco Seawater Used $10
2 Rubber Exhaust Gaskets New $5
1 Complete 90 Hp Gasket set # 139300 New $40
2 "used OMC Stator #583669, #583672, $20 ea
2 "used JOHNSON/ Evinrude Stator #583669, #583672, $20 ea
2 Johnson/Evinrude fuel fitingsNew $5 ea
1 Johnson/Evinrude set of new plastic engine throttle connector slides New $5
1 Johnson/Evinrude used VRO Oil Tank with hose & Pump & Sender Used in Excellent cont $75
1 Fuel Fittings Set male & Female old style Merc New $10
1 Fuel Fitting Honda New$5
1 Fuel Fitting Suuzki New $5
Teleflex throttle/shift CABLES OMC Johnson/Evinrude NEW!
2 Teleflex Black 12ft t shift/throttle cable OMC New $10 ea
1 Teleflex Black 15ft t shift/throttle cable OMC, Johnson/Evinrude New$10
3 Teleflex Black 12ft t shift/throttle cable Merc/MarinerNew $10 ea
4 Teleflex Black 16ft t shift/throttle cable Merc/Mariner New ea $15
1 Teleflex Black 23 ft shift/throttle cable MERC New $20
1 Teleflex Black plastic steering wheel New $10
1 remote steering Alum Bracket for the Merc/Force 9.9 or 15HP outboard motor.(May fit other brands)New $20
1 Plastic Pitot Tube pickup New $5
2 Battery Rotary Switchs used $10 ea
1 pair of Standard Battery to Engine Cables Used$25
2 Johnson/Evinrude electric fuel chokes Used $25 ea
1 Johnson/Evinrude 90 hp Carburator Used $20
1 Timer Base Kit #583376 Used$30
1 Johnson/Evinrude Rectifier Blue Power pack no part # Used$30
1 Johnson/Evinrude Rectifier/Regulator # CD4 #583336 23IM-0A Black Rectangle Used $75
1 Johnson/Evinrude Rectifier/Regulator #5114-04 DT-4 G Alum Metal Rectangle 3 wires? Used $30
1 Johnson/Evinrude Rectifier/Regulator # 395391 Used $50
1 Johnson/Evinrude pt/pt Relay Box with Cable Used $30
1 Recoil Starter Assembly for Merc/Force 9.9 or 15HP outboard motor. Used $30
4 Tilt Pins retainer Bars for Johnson/Evinrudes Used $10 ea
2 Stainless Steel Steering arms for outboards Used $25 ea
2 Stainless Steel Steering Coupler brackets Used $25 ea
2 Johnson/Evinrude Ignition coils #582508-0560-0A Used $50
1 Johnson/Evinrude OMC Stator #583672 Used $50
1 Johnson/Evinrude OMC Stator #583669, Used $50
4 Johnson/Evinrude ignition coils Used $10 ea
2 Johnson/Evinrude Flywheel Used $40 ea
1 Johnson/Evinrud Shift/Throttle control Housing, missing a couple parts Used $20 ea
1 Johnson/Evinrude 6 gal Plastic Fuel Tanks with fittings Used $20
3 Johnson/Evinrude TRIM TAB (adjusts outboard torque) 327640 Used $10 ea
4 Johnson/Evinrude Big heavy Alum wedge Motor Mounting Brackets to shim up outboard on transom Used $20 ea
1 Johnson/Evinrude plastic throttle shift handle with pt/pt switch Used $10
1 Johnson/Evinrude plastic throttle handle. Used $10
2 Johnson/Evinrude Tachometer used Used $5
