I need help with my Toro 20031 purchased in 2004. Don't know where a
javisnavi
  • / I need help with my Toro 20031 purchased in 2004. Don't know where a
Hi Friends,
I changed the belt of my Toro 20031 but I took apart more pieces than I should. I got a SPRING-TORSION part # 107-7472 that cannot find a way to install it back in place. If you can share pictures of your Toro 20031 where it shows where that piece is installed. I am attaching a picture of the spring plus a screen capture of the spring from the parts catalog. s-l300.jpgspring torsion.JPG.
Thank you,
Javier
primerbulb120
I don't have a 20031, but I'm guessing maybe it holds the bagger door closed??
EDIT: There could be two springs holding the bagger door closed, one on each side. Check to see if one is missing.
javisnavi
Thank you for your reply. The spring torsion I am talking about is not the one that keep the bagger door closed, I already checked those up. I believe this spring torsion keep the battery holder bar in place.
Catherine
LawnWorld Support
Welcome to the forum! :welcome:
I'm going to move this thread over to our Toro section.
Best of luck! :smile:
outsider
Hi. The spring you have pictured only holds the handle position release bar in place. I had trouble getting mine back in place so I eliminated the bar and springs entirely. The bag still lifts off easily and does not come loose. I find it is not inconvenient at all. Sorry I could be of no real help.
