I have a starting problem. Starter motor won't turn. I have replaced battery, starter and solenoid. Still wont turn starter motor. Voltage check on battry over 12 volts, voltage to solenoid 12 volts. When the key is turned to on position the voltage drops to 7 volts and when engaging to start position getting a buzzing sound, No voltage to starter. Is there something else I can check?
Thank you for any help
Geoff
Geoff
