muddingcountry05
- May 31, 2014
- 2
hi i have a simplicity coronet with the 8.5hp Briggs & Stratton motor and a peerless 915-016D 5 speed. I cracked that lower case on the transaxle I tried tigging it that cracks. Put the axle back under the mower tried to drive the mower to see if my fix worked. When I put in gear and let go of the brake i got a god afoul noise of grinding gears. So put it in neutral shut off the mower and looked at the axle. The lower case is no split in two! I wanna know what peerless transaxle will work in my mower? ( cause there are all kinds of peerless transaxles but i can never fin mine!):confused2:
