Hydrostatic transmission-Suddenly forward is weak
larryuno
I am finally able to followup on my post. HL was correct when he said cracked frame and brackets: not only the left frame weld failed but the stress broke the right frame rail as well just by the deck lifter brackets. I got a welder to join things back together realigned as closely as possible, and now the mower performs as it did before, which is a relief. I still await a frame rail repair kit, so I can return with confidence, just hope the manufacturer will proceed with heavier frame material and only frame perforations actually needed, in future. I measured the frame rail thickness at 2.5 mm thick, which is barely 12 guage (about 1/16th inch).
Gord, your comment is noted, but I used a Poulan with a 19.5 hp Briggs for 15 years on that farm, and only repaired the usual Briggs compression release, head gasket, and magneto issues on the engine. Otherwise, a lawn tractor would be useless for my use, and the hills are not overly long, so I will take the chance, thanks. The sumps appear to be sufficiently deep on Briggs, unlike what I hear about the Loncin Chinese engine.
Gord Baker
Gord Baker
On some engines with an Oil Pump it is where the Pickup Tube is located that governs constant lubrication on slopes. Glad you have it running again.
